Re: M Power Steering
Posted by Glennster on April 18, 2014 at 18:24:07 from (99.90.9.201):
In Reply to: M Power Steering posted by Robertw on April 18, 2014 at 17:21:36:
Its probably an aftermarket char lynn system. There should be a priority valve that taps off the live pump to run it. It uses the fluid in the hydraulic system.
