Re: M Power Steering
Posted by Bob M on April 18, 2014 at 18:30:30 from (65.110.157.186):
In Reply to: M Power Steering posted by Robertw on April 18, 2014 at 17:21:36:
Yours would not be a factory setup - PS was not offered from the factory for the Super M.
Your aftermarket PS - most likely a Charlynn - is supplied by the live hydraulic pump. As long as the level is up in the Liftall tank (hydraulic reservoir) there's plenty of fluid for the PS.
To isolate the source of steering play: Remove the hood. Now start the engine then turn the wheel back and forth while watching the PS torque generator output shaft.
If the output follows the input shaft with no observable slack, problem's in the steering gear/bolster assembly (the most common source of steering play on an SM). Otherwise problem's in the torque generator - most likely a broken centering spring.
