Several possibilities: The material of the gasket could be inferior or too thick. The pressure relief in the system could be stuck or sticking. The surface of the block or flange could be distorted. The block to flange bolts could be improperly tightened/partially stripped.
If the system loads the engine (makes it open the governor a little) with no lever movement it might be the valve adjustment.
Pressure testing it is in order. I hope this helps. Jim
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
