Re: Case IH Oil Drain Plug Won't Turn Loose
Posted by El Toro on April 19, 2014 at 10:54:45 from (96.244.7.206):
In Reply to: Case IH Oil Drain Plug Won't Turn Loose posted by Charles Beaverson on April 19, 2014 at 07:45:29:
Are you sure you're turning the drain plug CCW? Weld a nut on it and use your air impact wrench. Hal
