Super C Trans problem
Posted by Steve Reed (Mich) on April 19, 2014 at 15:27:06 from (99.54.88.140):
About two months ago I pulled the oil plug on the rear end of the Super C. When I did a bolt fell out. I just pulled the top off and found three bolts had fallen out and one plate that held the axles in place. I replaced the bolts added lockwashers and loctite. Putting the top back on I thought I had the forks all lined up. When I went to move it I found out I had no neutral, reverse in neutral and reverse. All four forward gears are locked up solid. Is it possible I put the reverse fork in the wrong spot? It does shift, but does not move. Thanks, Steve
