Did forget, change the oil pressure line fitting to the M one before installing the frame rail. Makes it easier anyway. Also a 450 manifold sometimes needs a little web grinding for the m throttle rod that passes between it and the head to not rub. Or the rod bent some. Sometimes the head studs on a 450 are not long enough for the M throttle bracket and a full nut.
Have in the past when running into that problem and couldn't get the head studs out to put longer ones in without head removal. Used long nuts like used on some spring U bolts on the head studs and torque down. Drill the bracket mounting holes big enough to pass over the nuts and rest against the head. Use short bolts in the long nuts above the stud with spacers cut from 1 inch thin wall pipe and a flat washer to hold the throttle bracket down.
This post was edited by D Slater at 03:10:10 04/20/14.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
