Re: 504 pto main drive gear
Posted by pete 23 on April 19, 2014 at 19:44:40 from (74.33.94.238):
In Reply to: 504 pto main drive gear posted by teachingscience on April 19, 2014 at 06:18:06:
Notice the early serial number tractors did not use a wedge. I believe on those the shaft was longer and came closer to going through the gear or the gear was slightly different. Some one may have done some changing over the years to try to keep that gear tight. I never saw one get loose that used the wedge. The older ones came loose and that is why they went to the wedge.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
