Re: Farmall Super C fast hitch hose block
Posted by Rick Remmert on April 19, 2014 at 20:27:05 from (68.103.4.23):
In Reply to: Farmall Super C fast hitch hose block posted by Rex Simpkins on April 19, 2014 at 16:33:45:
third party image
third party image
Here you go. The hose coming out of the spool valve goes to the right hand side of the block, the side with the valve head. That hose runs back and goes into the port on the cylinder that is on the outside of the of the cylinder. The hoses do not cross where they run under the seat. There are different opinions on here if you can bypass the valve or not. I would not do it for the simple reason of safety. I have a 5' rotary mower on mine, and it goes down fast enough with the valve.
