Re: 460 Hydro Questions! Please help
Posted by caterpillar guy on April 20, 2014 at 04:55:48 from (24.231.176.149):
In Reply to: 460 Hydro Questions! Please help posted by Matt in MO on April 19, 2014 at 22:07:12:
We had an 856 that had water in it like that setting the oil would look fine drive it a couple hundred feet and would be white. We just let it simmer on the stove in a kettle for a bit and evaporated the water out. This would work good to flush the system then change the oil this way you can remove the water without all the new oil cost. otherwise you will have to change the oil then change it again after you pump the new oil through the system to flush the old oil out. At 10.00 a gallon or there abouts the heat and flush by running for an hour is much cheaper. Then put your new oil in with a new filter.
