Re: What are there parts called....
Posted by mazemeister on April 20, 2014 at 06:07:47 from (173.3.248.237):
In Reply to: What are there parts called.... posted by funtwohunt on April 19, 2014 at 20:52:29:
what happens is the little cast elbow gets a grove worn in it from the o ring after all these decades, then the o ring won't seal. first thing to try is new o ring. if that doesn't work, what i did was use anaerobic gasket maker on the joint; don't forget the surface prep in the spray can. that solved the leak for me.
course you can buy new parts from case-ih, but they are very pricey.
