Re: Farmall M Engine
Posted by IAtractorKid on April 20, 2014 at 09:09:49 from (184.97.55.91):
In Reply to: Re: Farmall M Engine posted by steve_in_mo on April 20, 2014 at 07:20:59:
Ill try and get out in one of the neighbors fields next weekend if he hasn"t worked them already. Ill change the oil and substitute in a quart of ATF. Are the 388 plugs ok or should I change them out to something else?
Also, with the loader removed, I have no reservoir for the live hydraulic pump...can I just run a line from the drain plug of the belly pump to supply the pump and return to the fill hole on the belly pump? It will just be a continuous loop but at least it will have fluid!
Thanks for the help guys!
