"My question is what does the 3rd brush do and do I need it with a regulator"
The physical location of the third brush regulates the rate of charge. The closer it is to the fixed brush the more charge, the further away the less charge. Some 3 brush are adjustable (can set third brush closer or further away from fixed brush)
Early 3 brush gennys were seen often when a full fledged automatic Voltage Regulator WAS NOT USED but instead only a simple manual Low or High charge selector light switch.
However, in later years they still used some 3 brush gennys even when they went to a full fledged automatic Voltage Regulator. Later they went to 2 brush gennys and full fledged Voltage Regulators.
COMMON PROBLEMS are the brushes are worn down too short,,,,,,,,the fields may be open or shorted out,,,,,,,,,,,,The splice may be open or shorted where the 2 fields connect together,,,,,,,,,the armature may be shorted to case. A physical inspection and an ohm meter can test for much of that while a growler may be necessary for more precise accurate armatures testing.
Today's Featured Article - Women and Tractors - More Views From the Farmer's Wife - by Teri Burkholder. The top ten reasons why the judges wouldn't let you participate in the stock antique tractor pull: Hey, this is stock! It came with that V8 in it! That "R" on my tires stands for "really old" not radial! Blue gas? We thought it was a pretty color! What wire hooked to my throttle?
... [Read Article]
Latest Ad:
[More Ads]
