I always rolled the TA section ahead with the engine. The only down side to doing it that way is when it comes to adjusting the end play of the pto lower shaft bearing. Most of the tractors I was doing at that time were not all that old so most of them you checked before disassembly and if there was no bearing replacement required on that gear and shaft it was simple. If the bearing needs replacement you need to work through the bottom to adjust the clearance after the front section is bolted back together to rear and that is a pain.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
