Re: 1950 Cub Farmall won't run
Posted by Phil Auten (TX) on December 22, 2000 at 19:21:25 from (64.217.53.83):
In Reply to: 1950 Cub Farmall won't run posted by Bill Jolley on December 21, 2000 at 11:52:20:
Bill,
Disconnect the gas line at the carb and check for a good steady flow. If not, you will need to find the blockage and clean it out, including, possibly, the tank. My Cub had a bunch of crud in the tank and I was able to just flush it out and it works fine now. Also, add an inline filter between the sediment bowl and carb. It'll save you a bunch of work later on cleaning out the carb.
Also, make sure the vent hole in the gas cap isn't plugged. Had one of those too. :o)
My 2¢,
Phil
Post A Followup
: Re: Re: 1950 Cub Farmall won't run
