Re: got a cub
Posted by mkirsch on April 21, 2014 at 05:01:26 from (65.199.189.6):
In Reply to: got a cub posted by HenryO on April 19, 2014 at 18:44:46:
Can you explain more what you mean by "catches and won't return?"
Are all the parts moving freely? Is the spring in place?
Start at the throttle handle and follow the linkages into, then out of, the governor and make sure everything moves freely. You may need to squirt some penetrating lube and work things loose.
The spring is visible if you shine a light in from the left side and look across the front of the engine at the top of the governor. If it is stretched or missing replace it. It can be done with a long needle-nose pliers and some patience.
Owner's manuals don't tell you much about "mechanicing." Service manuals are what you need, but even those expect that you know more than the basics about wrenching on tractors. Don't set your expectations on an illustrated step-by-step procedure for taking your tractor completely apart and putting it back together like a Lego set.
