Re: farmall cub won't start
Posted by El Toro on April 21, 2014 at 07:02:25 from (96.244.7.206):
In Reply to: farmall cub won't start posted by scottsphere on April 21, 2014 at 06:28:29:
Remove No1 sparkplug near the radiator and bring that piston to TDC on the compression stroke. Then remove your cap on the distributor or mag and see where your rotor is pointing. It should be at the No1 plug tower on the cap. Also your plug wires need to be in this firing order on your cap:
2-1
4-3 As the rotor rotates CW. If you have a distributor you need battery voltage to your coil.
With the points open and your ignition switch on you should have battery voltage on both small terminals on the coil. Use a volt meter. Hal
