The link below is the answer for general wiring. The alternator needs to connect to the positive side of the battery at the starter motor battery connection. (It should have a fuse link in it that can handle the alternator rated output plus 10%. The volt meter also connects to this terminal and the negative side is grounded. They usually operate all the time, running or not. If the battery goes dead between running times, put a master switch in the positive battery cable that shuts off everything. Jim
Today's Featured Article - Field Modifications (Sins of the Farmer) - by Staff. Picture a new Chevrolet driving down the street without it's grill, right fender and trunk lid. Imagine a crude hole made in the hood to accommodate a new taller air cleaner, the fender wells cut away to make way for larger tires, and half of a sliding glass door used to replace the windshield. Top that off with an old set of '36 Ford headlight shells bolted to the hood. Pretty unlikely for a car... but for a tractor, this is pretty normal. It seems that more often than not they a
... [Read Article]
Latest Ad:
[More Ads]
