Re: 1466 brake and steering failure
Posted by Janicholson on April 21, 2014 at 15:03:40 from (74.60.94.18):
In Reply to: 1466 brake and steering failure posted by Yellott Canby on April 21, 2014 at 10:16:53:
Check the level of the hydraulic system if full put in an extra 5 gallons. It hurts nothing and floods an Oring that leaks on the intake side of the MCV pump. If it does not fix it, the MCV valve or system may be stuck. Try the extra oil! Jim
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
