Re: Drilling Out Oil Pan Drain Plug
Posted by Janicholson on April 21, 2014 at 16:57:23 from (74.60.94.18):
In Reply to: Drilling Out Oil Pan Drain Plug posted by Charles Beaverson on April 21, 2014 at 16:42:05:
Don't drill yet. Weld (or have welded) a nut that has an internal (thread diameter) that is almost the size of the chewed up part, to the exposed chewed up hex. The heat will cause it to break loose, and the nut can be turned to take it out. A wire welder (cheap at Harbor freight) with flux core (you were meaning to buy one) will do it. Jim
