Re: Weight in tires of Farmall C?
Posted by DeltaRed on April 21, 2014 at 18:53:00 from (65.100.144.27):
In Reply to: Weight in tires of Farmall C? posted by Smith1000 on April 21, 2014 at 18:30:25:
Yes,fluid/weight in both or none.If you just show,parade/drive around,mow..... and do not tractor pull,get the wt out!Heck,you can even do a little 'farming' without weight.A single weight can make a tractor easier to tip to the weighted side.Also,the weighted tire will grip and the non will spin...The result is worse than no wt.Drain em!
