Re: Drilling Out Oil Pan Drain Plug
Posted by DeltaRed on April 21, 2014 at 22:06:46 from (65.100.144.27):
In Reply to: Drilling Out Oil Pan Drain Plug posted by Charles Beaverson on April 21, 2014 at 16:42:05:
Best to remove the pan.To try and do it upside down would be LOTS more work.Do as Jin says,weld a nut to the stub.even if it's flush you should still be able to weld.Then you can clean up the surface a bit with a grinder,file...
