Re: Drilling Out Oil Pan Drain Plug
Posted by Phil Tibbetts on April 22, 2014 at 09:34:08 from (208.93.14.38):
In Reply to: Drilling Out Oil Pan Drain Plug posted by Charles Beaverson on April 21, 2014 at 16:42:05:
I've never seen a pipe fitting I couldn't get out by drilling the center out nearly to but not into the threads. Then heat up the remaining part red quickly on one side. Let it cool and the rest will come out easily. I would still take the oil pan off as you are going to get covered with oil if you try to drill it on the tractor.
