Re: Farmall h piston size
Posted by Zachary Hoyt on April 22, 2014 at 09:40:22 from (173.84.184.209):
In Reply to: Farmall h piston size posted by Walt2 on April 22, 2014 at 08:53:15:
I have either repaired or parted out about 10 or 11 Hs and I have never seen a 3-3/8" piston. I know they were stock but they must have all been swapped out over the past 70 years. The bore in the block is the same, the 3-7/16" just uses a thinner sleeve in the bore to accommodate the larger pistons.
Zach
