Re: Freeing a stuck motor
Posted by Jim Gorter on April 22, 2014 at 09:51:16 from (76.205.222.73):
In Reply to: Freeing a stuck motor posted by James Williams on April 22, 2014 at 05:45:08:
Depending on how badly the cylinders are stuck, I have had good success with a mixture of 50% auto trans fluid and 50% acetone. Put into each cylinder and let sit for a few days. I like to start with the easier methods and if needed go to the more aggressive approach.
