Re: Farmall h piston size
Posted by pete 23 on April 22, 2014 at 10:01:57 from (74.33.94.238):
In Reply to: Farmall h piston size posted by Walt2 on April 22, 2014 at 08:53:15:
All H Farmalls were 3 3/8 piston case iron piston.. Even the original power packs with aluminum pistons were 3 3/8th. Then, well after end of production the thin wall sleeve was introduced,(probably because after market suppliers were already doing so} and had the 3 7/16th piston. Ironically, the Diesel engines used aluminum pistons before the gasoline engines did.
