Posted by kub6040 on April 22, 2014 at 10:40:47 from (54.234.162.108):
In Reply to: Freeing a stuck motor posted by James Williams on April 22, 2014 at 05:45:08:
I have had good luck with acetone no atf . Once rust is loose enough to let by rings it will turn , at this time I use the 50/50 mixture until loose enough to remove parts that need replacing, if cylinders aren't bad you may still want to remove pistons and hone lightly
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
