Posted by El Toro on April 22, 2014 at 19:17:26 from (96.244.7.206):
In Reply to: C with no spark posted by deake on April 22, 2014 at 16:05:15:
With the points open and the ignition switch on you should have battery voltage on both small terminals on the coil. If you're still using the 6 volt battery the wire from the coil should be on the + terminal of the coil to the points. The battery was positive grounded.
If it was converted to 12 volts the coil wire is on - minus terminal of the coil to your points. Make sure your points are set at .020" on the distributor cam lobe. Use a volt meter to see if you're getting battery voltage to your coil. Hal
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
