Re: C with no spark
Posted by Janicholson on April 22, 2014 at 20:35:37 from (74.60.94.18):
In Reply to: C with no spark posted by deake on April 22, 2014 at 16:05:15:
With the center high voltage coil wire 1/4" away from the engine block and attached to the coil(use tape).
And the trans in neutral brakes set.
Points open by being on the distributor cam high spot.
Distributor cap off and points visible.
Ignition turned on (for less than 3 minutes)
Use a screw driver to carefully bridge across the points. Just make contact across the two contacts making a connection. Make and break this connection with the screw driver. It should spark a little at the tip of the screw driver. It should spark a lot at the coil wire to block gap.
If not the points might be connected to the terminal wrong, shorting to the distributor housing. Or the wires are touching ground inside the distributor.
Let us know what you find. Jim
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
