Which tractor? An A B or C will have an air cleaner intake, an oil breather cap, and an exhaust pipe. (it may also have a fuel cap or starting tank cap as well.) Of these the oil fill cap will (and should) smoke a little. That is OK, as it is designed to do it. The air cleaner should not smoke and that has the oil bath. An H or M or bigger tractor has only a air intake to the engine through a oil bath those also do not smoke unless something is way worn or broken. Jim
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
