Re: C with no spark
Posted by John T on April 23, 2014 at 05:24:16 from (216.249.72.121):
In Reply to: C with no spark posted by deake on April 22, 2014 at 16:05:15:
"I find that there is voltage on the output terminal when the points are closed and none when they are open, seems as if something is reversed"
YES THATS BASS ACKWARDS
DEFINITIONS: (Regardless of Polarity)
The coils INPUT is the terminal that receives voltage via the Ignition switch when ON.
The coils OUTPUT is the terminal that wires to the little side post/terminal on the Distributor, and from there to the points and to ground when they are closed so coil conducts current.
A test lamp or voltmeter on the coils INPUT should light or register voltage (with respect to frame ground) anytime and all the time the IGN is ON. A test lamp on the coils OUTPUT (to distributor) should read voltage when points are OPEN but zero voltage (no light) when closed (cuz the points short it out to frame ground).
1) If the light on the output IS ALWAYS LIT EVEN IF POINTS ARE OPEN OR CLOSED...... The points are badly burned or not fully closing or aren't getting a good ground via the distributor or the wiring or wires aren't right or the wires open from coil to distributor THE COILS OUTPUT ISNT GETTING GROUNDED OUT SO COIL CURRENT FLOWS..
2) If the light on the coils output NEVER LIGHTS UP.......The coils LV primary (from little + and - terminals) is bad/open, it should be around 1.25 to 4 ohms NOT an open circuit,,,,,,,,,,,,,The points are remaining closed,,,,,,,,or the condenser is dead shorted (try disconnecting it),,,,,,,,,or the points or their wiring is shorted,,,,,,,,,or the distributors little side terminal pass through has bad insulation and is shorted out to case.
A lamp on the coils output should flash ON (points open) and OFF (points closed) as the engine is slowly cranked over.
Digest all this n let us know
John T
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
