Re: Farmall M--persistent coolant leak after overhaul
Posted by John M on April 23, 2014 at 11:28:17 from (68.115.194.228):
In Reply to: Re: Farmall M--persistent coolant leak after overhaul posted by littlefarmer on April 23, 2014 at 10:19:58:
Its on the very front of the block itself. You have to pull the timing cover, and the plate to see it. not all of them have it.
