Re: Wide front for 300 Farmall
Posted by rustyfarmall on April 23, 2014 at 14:32:47 from (208.126.186.41):
In Reply to: Wide front for 300 Farmall posted by 56 Fan 400 on April 23, 2014 at 13:57:55:
6 bolt hubs will let you mount some WIDE rims and tires for greater flotation. Also, those original cast iron hubs and 3 bolt rims have a tendency to break with a heavy load such as an F11 will place on them.
