Re: Farmall M--persistent coolant leak after overhaul
Posted by littlefarmer on April 23, 2014 at 16:28:16 from (74.46.126.65):
In Reply to: Re: Farmall M--persistent coolant leak after overhaul posted by kevinj54 on April 23, 2014 at 10:58:46:
The block was completely removed from the frame.
