Re: Farmall 400 power steering
Posted by Aces on April 23, 2014 at 17:36:34 from (64.5.67.237):
In Reply to: Farmall 400 power steering posted by Newby mechanic on April 23, 2014 at 16:36:24:
Your have a priority system on the 400. That means the power steering should get 3 gal PM first. But if the flow control valve is not working right you end up with what you have. Could be the spring for the flow control valve is bad the valve spool is worn bad, stuck, or a worn orifice. No adjusting to do here. If the valve body is worn bad not much One can do but replace the whole valve. Need to take the flow control valve apart and check it out. This is why I never used a flow control on older SM SMTA.
