Re: 1959 Farmall Cub setting point gap?
Posted by DGinVT on April 24, 2014 at 08:30:05 from (75.105.0.38):
In Reply to: 1959 Farmall Cub setting point gap? posted by scottsphere on April 24, 2014 at 07:39:16:
The points shud be set at .020 with the rubbing block on the high point of the cam. Also check gap on plugs and make sure you have the wires in the right firing order. Closely examine the inside of the cap for carbon tracks and cracks. Replace if necessary. Also check the rotor for pitting. Cap and rotor go as a pair, just like condenser and points. Your timing might not be quite right also.
