Re: Farmall 806 propane
Posted by Hugh McKinney on April 24, 2014 at 12:35:49 from (66.208.143.3):
In Reply to: Farmall 806 propane posted by avant tractor on April 24, 2014 at 10:51:00:
You could have a perforated diaphragm on the high pressure side, or the screws could need tightening on that cover plate on the high pressure side. On Ensign converters, high pressure is the smaller plate. You could also have a little bit of foreign matter in the low pressure valve that is actuated by the larger, low pressure, diaphragm. If you email me I can walk you through it. Hugh McKinney
