Re: SC clutch
Posted by farmallhal on April 24, 2014 at 19:12:06 from (76.2.168.209):
In Reply to: SC clutch posted by DeltaRed on April 24, 2014 at 16:39:52:
Delta, Have her move the gear shift lever all the way to the right and try and push it forward (there is no gear there) and hold it firmly forward a coupe of seconds and I believe you will find that position acts like a transmission brake when changing gears stopping the gears for a clash free shift. I have found that works very well on my SC and 140 when shifting between gears. Hope this helps as someone mentioned it on this forum a long time ago and I found it really does helps a lot, Hal.
