Re: Farmall 400 power steering
Posted by Aces on April 24, 2014 at 19:51:43 from (64.5.67.237):
In Reply to: Re: Farmall 400 power steering posted by Newby mechanic on April 24, 2014 at 16:42:38:
I know it is factory set up. It is a priority system if the flow divider doe not work right no oil to steering. But when you move a hydraulic lever and stop the oil it has to go to the steering. If you had a cylinder on that valve the steering still would not work. So I say flow divider, dirt, bad spring. bad ball or seat, o ring.
