Re: Farmall A Knock Knock is no joke.
Posted by BONO ANTIUE TRACTOR on April 24, 2014 at 21:04:42 from (199.68.231.4):
In Reply to: Farmall A Knock Knock is no joke. posted by Mark J in Mi. on April 24, 2014 at 19:31:05:
COULD ALSO BE A THROUGHT BEARING ON THE CLUTCH SHAFT. WILL HEAR IT IN NUETRAL ONLY
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
