Re: SC clutch
Posted by NNP on April 25, 2014 at 03:47:19 from (66.66.112.196):
In Reply to: SC clutch posted by DeltaRed on April 24, 2014 at 16:39:52:
adjust the clutch.
heaviest oil specified in the trans.
use the shifter 'dead' spot gear brake trick.(with my SC's that's usually all that's needed.)
depending on the operators safety consciousness, leave the belt pulley engaged for more drag.
Above all, be patient
as an example, on my SH which has no belt pulley, just the assembly and flange. I leave it engaged so the flange is spinning.
Pushing the clutch in when the oil is warm, it takes quite awhile for the flange to stop rotating.
When it stops....shift
Same with other models inside the trans, just not as easy to see.
