Don't waste your time trying to pull start the tractor. It may start, but what does that prove? Are you going to wait for a friend to come over and pull start you EVERY time?
When you think you have everything correct, but it still won't start, you've got one of two problems:
1. Something is NOT correct. I don't care what you think or how many times you checked. There is something out of place, period. If a decent engine has air, fuel, and spark at the right time, it WILL start.
2. The engine as a serious internal problem either causing a loss of compression or causing the valves to operate incorrectly (i.e. stuck valve, broken cam gear, etc.)
If you can, get a compression reading on all four cylinders. Check your timing again. Make sure you're getting spark at the plugs.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
