Re: spark plugs for an H
Posted by rustred on April 25, 2014 at 18:35:49 from (74.214.152.80):
In Reply to: Re: spark plugs for an H posted by Rat in Can on April 25, 2014 at 12:18:00:
D 16 is the factory plug that most of these different models came with from factory. you can go to the next higher heat range with no problem.
back then the tractors earned their keep in the field with long hrs. with D16 plugs. now these old tractors are a hobby thing and need a hotter plug for all the cold starts and stops and hardly even get to operating temp. very bad for an engine. they have to be put to work hard every so often.
