Posted by Janicholson on April 25, 2014 at 19:40:18 from (74.60.94.18):
In Reply to: farmall m shifter posted by butch49 on April 25, 2014 at 19:31:45:
Just below the spring and dome shaped plate on the shifter there are two metal plugs. Pull one out with a slide hammer or? to remove the pivot pin by driving it through the other plug. Remove the lever. If the pivot is worn replace it with a piece of grade 8 bolt shank, or buy a sloppy shifter repair kit from Ebay (recommended) If the rails in the trans are not aligned, push the clutch and move them with a big screw driver or small pry bar till they are aligned in neutral. The tip of the lever may also be worn. There are images in the archives of the tip with dimensions. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
