Re: Crank Shaft Bearing
Posted by El Toro on April 26, 2014 at 13:42:03 from (96.244.7.206):
In Reply to: Crank Shaft Bearing posted by Dave8N in Pa on April 26, 2014 at 09:53:52:
What's the condition of the pistons? If the bearings are worn your crankshaft may be worn and should be measured. That means the crankshaft needs to removed. Hal
