Re: Hydro 86 hydraulics/hydro sucking air
Posted by Matt Compton on April 26, 2014 at 14:56:11 from (24.137.113.53):
In Reply to: Hydro 86 hydraulics/hydro sucking air posted by Matt Compton on April 25, 2014 at 13:37:37:
Thanks for the reply guys but this problem still exists after the filter change. what about the o-rings around the suction manifold? see as how its causing issues on both hyd pumps? if so how hard is it to get at and do you have to drain all the oil? Also i"m sure you guys will scold me but our case dealer is over an hour away and the deere boys are 2 minutes down the road. so we use JD Hy Gard for hydraulic oil............. Could that be the problem too?
