Re: 350 utility hydraulic pulse
Posted by Janicholson on April 26, 2014 at 17:33:24 from (74.60.94.18):
In Reply to: 350 utility hydraulic pulse posted by Dj In Pa. on April 26, 2014 at 17:11:53:
There is a pilot valve in the demand driven hydraulic. It is located in the hydraulic block on the right side (see parts diagram in caseih.com) this orifice can become partially blocked, and it also has a screen that plugs up. If it is .030" it might be drilled to .040" to reduce or eliminate the pulsing. Jim
