Re: Hydro 86 hydraulics/hydro sucking air
Posted by IH fan on April 27, 2014 at 05:38:31 from (174.70.169.139):
In Reply to: Hydro 86 hydraulics/hydro sucking air posted by Matt Compton on April 25, 2014 at 13:37:37:
Good chance it is ice, but if it works after it warms up, it could just be the cold oil. How cold is it when this happens? If it's well below 0, the oil is about like molasses and it takes a while to thin out. If it never works right after warming up, get some Hy-Tran. I wouldn't mix the oils, mixing or the wrong oil can cause problems with seals, just drain and re-fill.
We used to test down to -40 and if you don't let them idle until the hydraulics are warmed up, you can have real trouble. We ran some Olivers at -30 in our cold chamber (capable of -60)because the drivers that loaded the tractors in Charles City were revving the engines when cold and ruining new pumps because of cavitation. They changed their policy to starting them and letting them idle a few minutes before driving.
