Re: Farmall M Engine...Update
Posted by Centex Farmall on April 27, 2014 at 07:15:24 from (72.105.166.241):
In Reply to: Farmall M Engine...Update posted by IAtractorKid on April 27, 2014 at 06:32:07:
I would look for an intake manifold leak and also pull the head pan again and do a preliminary check to see if one or more valve guides are excessively worn. You could be leaking air and oil past the guides.
Also check air cleaner to see if the intake pipe is not choked with years of crud
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
