Re: Carb. float measurment and preasure releaf valve
Posted by Phil Auten (TX) on December 23, 2000 at 11:01:49 from (64.217.53.85):
In Reply to: Carb. float measurment and preasure releaf valve posted by Bill jolley on December 23, 2000 at 09:42:49:
Bill,
My I&T manual says 1-13/32" from bottom of float to top of float bowl plus gasket. 1-3/8 is only 1/32" off, so you probably have it just a tad high, but probably in the functional range.
Pressure relief valve for what? The Touch Control? If that's what you mean, it appears to be under the bottom plate of the unit, near the center. Sounds like you really will need a manual for that. Suggest you wait 'til Binder is back up again.
Phil
Phil
Post A Followup
: Re: Re: Carb. float measurment and preasure releaf valve
