Towing tractor behind pickup
Posted by Ace Schrunk on December 23, 2000 at 11:08:55 from (205.188.197.169):
The other day as i worked in my yard some ome went buy with a H towing behind pickup, this is not a good idea because the tranny pilot bearing will not oil properly. If the constant mesh gears are not turning the pilot bearing doe not oil like it should. The engine must be running for the constant gears turn to splash oil to the pilot bearing. This is true for most IH tractors newer ones get some lube from hyd oil return but still need engine running
Post A Followup
: Re: Towing tractor behind pickup
